StarTech.com 4x4 VGA Matrix Video Switch Splitter with Audio
£257.65
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Allows four PCs / Media Players to provide video to four displays / projectors
  • Daisy chain an additional unit for use with seven sources and seven displays
  • Equipped with easy to use front panel selection buttons
  • High video bandwidth provides resolution of up to 1920 x 1440 pixels
  • Stock Status: In Stock
Product codes
Share up to four distinct VGA inputs and audio source signals between multiple monitors. The ST424MX 4x4 VGA Matrix Switcher/Splitter allows users to share up to four distinct VGA inputs (as well as corresponding audio source) between four independent displays or projectors.
Providing convenient push button control, the VGA Matrix Switcher/Splitter allows each of the four input VGA signals and the corresponding audio, to be switched individually meaning that you can have a different source showing on each display or one source showing on both offering maximum flexibility and control.
To ensure optimized VGA distribution and signal management even over longer distance signal transmissions, the ST424MX VGA Matrix Switcher/Splitter features a built-in signal booster that facilitates installation of displays at distances of up to 210ft away from the source device, while maintaining flawless signal integrity.
Designed to provide maximum control while saving space and eliminating clutter, the ST424MX can be used as a standalone solution or rack mounted using the (included) ear-mounts.
Product Description StarTech.com 4x4 VGA Matrix Video Switch Splitter with Audio - video/audio switch - 4 ports
Device Type Video/audio switch - 4 ports
Subtype VGA / audio
Dimensions (WxDxH) 26.9 cm x 10.4 cm x 4.2 cm
Weight 1.1 kg
Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 4x4 VGA M...
£257.65
