StarTech.com 5.1 Channel PCI Surround Sound Card Adapter
£14.12
Delivery:
Key features
  • 5.1 channel surround sound output and mic/line audio input via 3.5mm mini-jacks
  • Supports up to 48KHz/16-bit sampling rate
  • Includes low profile/half-height installation bracket
  • Supports HRTF 3D audio, Microsoft DirectSound/ DirectSound 3D, and A3D
  • Supports PCI Version 2.2 with ACPI
  • Full-Duplex operation for recording and playback
  • Three internal auxiliary inputs
  • Built-in 32 OHM Earphone buffer
Product codes
Add 5.1 channel audio to a desktop PC through a PCI slot. The PCISOUND5CH2 PCI Surround Sound Card lets you add 5.1 channel audio to a desktop PC through a PCI slot, giving you audio output, and microphone/line input via 3.5mm mini-jacks.
A cost-effective multimedia solution for delivering high quality surround sound, this PCI sound card lets you enjoy full-duplex, 48KHz/16bit audio playback/recording, and offers support for HRTF 3D positional audio, Microsoft DirectSound, DirectSound 3D, and A3D .
Three internal auxiliary input connectors let you connect your CD drive directly to the sound card. If your drive features external control buttons, the card allows playback without impeding your computers performance.
With support for PCI v2.2 and an included low profile/half-height installation bracket, this sound card is an ideal home theater PC solution that's perfect for your standard or small form factor (SFF) PC.
StarTech.com 5.1 Channel PCI Surround Sound Card Adapter - sound card
Sound card
Enclosure Type
Internal
Interface Type
PCI
1.9 cm x 12.1 cm x 12.2 cm
90 g
Signal Processor
CMI-8738 LX
Sound Output Mode
DAC Resolution
16-bit
Sample Rate
48 kHz (max)
Linux 2.6.x, Microsoft Windows Vista / XP / 7, Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2008 R2 (32/64-bits), Microsoft Windows Server 2012 (32/64-bits), Windows 8.1 (32/64 bits), Windows 10 (32/64 bits)
2 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 5.1 Chann...
£14.12
