StarTech.com 5 Port Gigabit PoE Switch
£125.90
Delivery:
Key features
  • PoE-powered device provides installation flexibility
  • Integrated PSE ports can save you money
  • Redundant power input gives you peace of mind
  • Type: Gigabit Ethernet
  • Ports: 5
  • Managed: No
  • POE: PoE+
Product codes
Connect five Ethernet devices to your network, including two Power over Ethernet (802.3af) devices, even in locations without a power source. This PoE-powered 5-port Gigabit Ethernet switch expands your network connectivity in remote locations where a power source is not available. For added versatility, you can power and network your Gigabit PoE-powered devices (PD) using two 802.3af PSE (Power Sourcing Equipment) ports. The durable metal housing and redundant power input make the switch ideal for harsh environments.
The Gigabit network switch is powered through your existing PoE network infrastructure, so you can deploy it without an external power adapter. Plus, you have more flexibility to install the switch exactly where you need it, with no added aggravation or costs. Plus, the switch supports the most common types of PoE power input, including 802.3af/at networks.
This Power over Ethernet switch features two 802.3af ports, so you can deliver power and data to your PoE PDs without the costs of additional PoE injectors or switches. The PoE switch provides 15W of total power output across both ports. Now you can adequately power and connect your PoE devices such as IP phones and cameras in situations where a typical AC-powered network device can't be used.
For applications where a power source is available, you can connect the optional power adapter and deliver up to 15W to each PSE port.
For added reassurance and convenience, the 5-Port Gigabit Ethernet Switch offers redundant power input using the included power adapter. With both PoE and AC power input, the versatile switch can remain operational during power dips, failures, or outages, making it perfect for factories, warehouses, and other industrial environments.
Product Description StarTech.com 5 Port Gigabit Ethernet Switch - PoE-Powered - 2 PSE/PoE Ports - switch - 5 ports - unmanaged
Device Type Switch - 5 ports - unmanaged
Subtype Gigabit Ethernet
Ports 5 x 10/100/1000
Power Over Ethernet (PoE) PoE+
Performance Forwarding performance (full duplex): 2 Gbps
MAC Address Table Size 4000 entries
Jumbo Frame Support 9KB
Features Flow control, auto-negotiation, store and forward, half duplex mode, full duplex mode, 128KB packet buffer
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at
Power AC 120/230 V
Dimensions (WxDxH) 8.4 cm x 15 cm x 2.6 cm
Weight 355 g
Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 5 Port Gi...
£125.90
