StarTech.com 5 Port Unmanaged Energy-Efficient Gigabit Ethern...
StarTech.com 5 Port Unmanaged Energy-Efficient Gigabit Ethernet Switch
£19.93
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Reduce energy consumption through 802.3az compliance
  • Occupy less space, with a compact desktop or wall-mountable enclosure
  • Network devices quickly and easily with auto-negotiating 10/100/1000 Mbps ports
  • Type: Gigabit Ethernet
  • Ports: 5
  • Data Transfer Rate: 1Gbps
  • Managed: No
  • POE: No
Product codes
The DS51002 5-port unmanaged Gigabit Ethernet switch lets you network up to 5 Ethernet devices through an energy-efficient gigabit switch, designed for desktop or wallmount installations.
Compatible with 10/100/1000 Mbps networks, this 5 port switch supports full/half-duplex auto-negotiation, jumbo frames and auto MDI/MDIX operation, allowing you to connect your network devices quickly and easily with little to no configuration required.
This unmanaged switch supports the IEEE 802.3az energy-efficient Ethernet standard, which offers power-saving features without compromising performance. The switch can automatically power down ports without a link, budget power output based on cable lengths and can also reduce the power consumption in idle or low-traffic modes.
Product Description StarTech.com 5 Port Unmanaged Energy-Efficient Gigabit Ethernet Desktop / Wall Mount Network Switch - switch - 5 ports - unmanaged
Device Type Switch - 5 ports - unmanaged
Subtype Gigabit Ethernet
Ports 5 x 10/100/1000
Performance Forwarding performance (full duplex): 2 Gbps
Jumbo Frame Support 16KB
Features Auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward, half duplex mode, full duplex mode, Energy Efficient Ethernet
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3az
Power AC 120/230 V
Dimensions (WxDxH) 18 cm x 12 cm x 3.01 cm
Weight 215 g
Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 5 Port Un...
£19.93
