StarTech.com 5 Port Unmanaged Industrial Gigabit PoE Switch w...
StarTech.com 5 Port Unmanaged Industrial Gigabit PoE Switch with 4 Power over Ethernet ports
£199.20
Delivery:
Standard: 1-3 working days
  • Type: Gigabit Ethernet
  • Ports: 5
  • Data Transfer Rate: 1Gbps
  • Managed: No
  • POE: PoE
Product codes
Connect Gigabit Ethernet and power to 4 PoE-enabled devices, with 15.4W per-port output. The IES51000POE 5-Port Gigabit PoE Switch with 4 PSE ports lets you connect Gigabit Ethernet and power to up to 4 PoE-enabled devices, or a mixture of PoE and non-PoE components.
Giving you the freedom to place your equipment in locations where power outlets are not available, this compact Power over Ethernet switch complies with IEEE 802.3af standards and supplies up to 15.4 W per port, with a total power budget of 62W. A true unmanaged switching solution, the 4 PSE (Power Sourcing Equipment) ports sense whether the connected devices are PoE-ready or require data connectivity only, while all 5 ports auto-negotiate between 10/100/1000 Mbps network speed and duplex.
The Gigabit Ethernet switch features a sturdy, wall-mountable metal enclosure for durability, and front panel LEDs for quick indication of connection speed and status.
Product Description StarTech.com 5 Port Unmanaged Industrial Gigabit PoE Switch with 4 15.4W Power over Ethernet ports - Wall Mountable PoE Network Switch (IES51000POE) - switch - 5 ports - unmanaged
Device Type Switch - 5 ports - unmanaged
Subtype Gigabit Ethernet
Ports 4 x 10/100/1000 (PoE) + 1 x 10/100/1000
Power Over Ethernet (PoE) PoE
PoE Budget 62 W
Features Power over Ethernet (PoE), auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward, half duplex mode, full duplex mode
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3x
Power AC 120/230 V
Dimensions (WxDxH) 9 cm x 13 cm x 2.8 cm
Weight 366 g
Colour Black
Localisation North America, United Kingdom, Europe
Designed For P/N: NETRS2321P
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 5 Port Un...
£199.20
