StarTech.com 5 Port USB 3.1 (10Gbps) Card
£50.23
Delivery:
Standard: 1-3 working days
Key features
  • Connect a USB-C device, plus a range of other USB devices, to your computer, regardless of their speed or connector type
  • Offers a high-performance USB-C port (10Gbps), two USB-A ports (5Gbps), and one 20-pin internal IDC motherboard header that can provide two USB-A ports (5Gbps)
  • Works with your existing USB 3.0 and USB 2.0 devices, for cost-effective backward compatibility
  • Wired / Wireless: Wired
  • Protocol: SuperSpeed USB 3.0, USB 2.0, USB 3.1
  • Compatibility: Mac, PC, Unix
  • Type: USB adapter
  • Stock Status: In Stock
Product codes
Add a USB Type-C (USB 3.1 Gen 2 - 10Gbps) port to your computer, plus two USB Type-A ports, and two motherboard-style headers (5Gbps). This 5-port USB 3.1 combo card makes it easy to add to the performance and connectivity of your computer. It's one of the only USB 3.1 cards to offer a USB Type-C port (10Gbps), traditional USB Type-A ports (5Gbps), and a motherboard header.
By offering a range of USB port types, you can easily connect a variety of modern and legacy USB devices, both inside and outside your computer.
Because the card offers a 10Gbps USB-C port (USB 3.1 Gen 2), you can save time and avoid the performance bottlenecks that are often associated with other connectivity technologies.
This versatile PCI Express combo card leverages the performance potential of USB 3.1 to help you work faster. The USB-C port offers a data throughput of up to 10Gbps, so you can spend less time waiting for file transfers to complete or for access to your external peripherals.
Plus, you can rest assured that you're set for the future, as USB-C devices become more popular and more standardized.
Now you can easily add a variety of types and speeds (generations) of USB ports to your desktop or server, using a single adapter card. The card features: One external USB-C port (USB 3.1 Gen 2 - 10Gbps); Two external USB-A ports (USB 3.1 Gen 1 - 5Gbps); Two internal USB-A motherboard header ports (USB 3.1 Gen 1 - 5Gbps).
With a range of port types, the card lets you bridge the gap between older and newer devices that use different connectors. You can simultaneously connect and access USB Type-A and USB Type-C devices, while using only a single PCI Express expansion slot.
By adding three types of USB ports in one combo card, you can free up space in your PC case, and eliminate the nuisance of having different cards for different USB devices.
With two internal motherboard-style headers, this dynamic USB 3.1 card is perfect for upgrading or building your own computer. If your existing headers are occupied, or if you don't have any motherboard headers, you can connect front panel hubs or card readers using this versatile alternative to costly motherboard or computer upgrades.
Connecting your older peripherals isn't a problem. This 5-port USB 3.1 card is backward compatible with legacy USB 3.0 and 2.0 devices, so you can eliminate the added expense and aggravation of purchasing new devices. (USB 3.0 is also known USB 3.1 Gen 1).
The card does not support DP alt mode or USB Power Delivery.
Product Description StarTech.com USB 3.1 PCIE Card - 5 Port - 1x USB-C - 2x USB-A - 1x 2 Port IDC - Internal USB Header Expansion - USB C PCIe Card (PEXUSB312EIC) - USB adapter
Device Type USB adapter
Form Factor Plug-in card
Interface (Bus) Type PCI Express
PCI Specification Revision PCIe 3.0
Ports USB 3.1 Gen 2 x 1 + USB 3.0 x 2 + USB 3.0 (internal) x 2
Dimensions (WxDxH) 1.8 cm x 7.93 cm x 12 cm
Weight 100 g
Data Link Protocol USB 2.0, USB 3.0, USB 3.1
Data Transfer Rate 10 Gbps
Processor ASM1142
Compliant Standards USB 2.0, USB 3.0, xHCI, USB 3.1
System Requirements Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Apple OS X 10.8 Mountain Lion, Apple OS X 10.9 Mavericks, Apple OS X 10.10 Yosemite, Microsoft Windows 7 / 8 / 10, Linux 3.5
Designed For P/N: CFASTRWU3C, FCREADU3C, HB30C3A1GEA, HB30C3AGEPD, HB31C2A1CGB, HB31C2A1CGS, HB31C2A2CB, HB31C3A1CB, HB31C3A1CPD3, HB31C3A1CS, HB31C3ASDMB, HB31C4AS, S251BRU31C3, S352BU313R, SDMSDRWU3AC, TB31PCIEX16, USB3C2ESAT3
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 5 Port US...
£50.23
