StarTech.com 50 ft Coax High Resolution Monitor VGA Video Cab...
StarTech.com 50 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M
£27.50
Delivery:
Key features
  • Extends your VGA signal to work with your monitor, splitters, and projectors
  • Supports high resolution VGA video (1920x1200 or above), suitable for a wide range of applications
  • Ferrite cores help eliminate EMI interference
  • Backed by StarTech.com Lifetime warranty
Product codes
The MXT101MMHQ50 High Resolution VGA Cable (50ft) is designed to provide the highest video quality possible through VGA, ideally suited for high resolution applications of 1920x1200 and above.
This durably constructed coaxial VGA video cable (HD15 to HD15) eliminates the picture "ghosting" and fuzzy images that are inherent to non-coaxial VGA cables, while delivering superior EMI interference protection by using ferrite cores near the connector ends.
Product Description StarTech.com 50 ft / 15m Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M (MXT101MMHQ50) - VGA cable - 15.2 m
Type VGA cable
Technology Triple shielded twisted pair coaxial
Features Molded, ferrite bead
Length 15.2 m
Connector HD-15 (VGA) - male
Connector (Second End) HD-15 (VGA) - male
Colour Black
Designed For P/N: CDP2VGA, CDP2VGAFC, DS128, DSRXL, DVI2VGAE, DVISPL1VV, DVIVGAMF, DVIVGAMFBK, HD2VGAE2, HD2VGAMICRO, ST122LEU, ST124L, ST128L, VGAPLATE
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
StarTech.com 50 ft Coa...
£27.50
