StarTech.com 50 ft Coax High Resolution VGA Monitor Extension...
StarTech.com 50 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F
£39.87
Delivery:
Standard: 1-3 working days
Key features
  • Ferrite core eliminates EMI interference
  • Ideal for high resolution monitors (1920x1200 and above)
  • Impadence matched at 75 Ohms for full brightness and vibrant picture color
  • Molded connector ends with strain relief
  • Triple-coaxial + twisted-pair wire for crystal clear display
Product codes
This 50ft High Resolution VGA Extension Cable is designed to provide the highest video quality possible through VGA.
Ideally suited for high resolution VGA applications, this high quality male to female coaxial VGA extension cable helps to eliminates picture "ghosting" and fuzzy images inherent to non-coaxial cables, and provides superior EMI interference protection by using ferrite cores near the connector ends.
Product Description StarTech.com 50 ft High-Res Coaxial SVGA Monitor Extension Cable M/F - VGA extension cable - 15.2 m
Type VGA extension cable
Features Molded
Length 15.2 m
Connector HD-15 (VGA) - male
Connector (Second End) HD-15 (VGA) - female
Designed For P/N: ST128UTPEAGB, ST122VGAU, ST128WGB, ST124WGB, ST122WGB, ST128UTPEA, ST128W, ST124W, ST122W, ST128UTPE, ST124UTPE, ST224MXGB, ST122PROAGB, ST124PROGB, ST122PROGB, ST128GB, ST222MX, ST122PROA, ST1216PRO, ST128PRO, ST122PRO, ST124PRO, ST128
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 50 ft Coa...
£39.87
