Make Power-over-Ethernet-capable Gigabit network connections. The N6PATCH50PL Cat 6 Patch Cable (50 ft) meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections, and features a durable purple PVC jacket that enables you to color code your network cable runs as needed. To ensure long-lasting performance, this high quality Cat 6 patch cable features a snagless design that protects the RJ45 connector clips from damage and makes the cable less prone to snagging during installation. The cable also features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance. Constructed of only top quality materials, this Cat 6 Patch Cord delivers reliable performance.
Product Description | StarTech.com 50 ft Purple Cat6 / Cat 6 Snagless Patch Cable 50ft - patch cable - 15.2 m - purple | Type | Patch cable - CAT 6 | Technology | Unshielded twisted pair (UTP) | Wiring Scheme | T568B | Features | Snagless | Length | 15.2 m | Connector | RJ-45 - male | Connector (Second End) | RJ-45 - male | Colour | Purple | Manufacturer Warranty | Limited lifetime warranty |
General | |
Network Cable Type | Patch cable - CAT 6 |
Jacket Material | PVC |
American Wire Gauge (AWG) | 24 |
Length | 15.2 m |
Colour | Purple |
Connectivity | |
Miscellaneous | |
Compliant Standards | RoHS, ETL - up to 650 MHz |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
