StarTech.com 50x10mm Replacement Ball Bearing Computer Case F...
StarTech.com 50x10mm Replacement Ball Bearing Computer Case Fan TX3/LP4 Connector
£6.97
11 in stock
Delivery:
Standard: 1-3 working days
  • Type: Case Fan
  • Stock Status: In Stock
Product codes
Overheating hardware can be a problem in most Server rooms. With StarTech.com's new LP4 Replacement Ball Bearing Fan, you can avoid problems to workstations. This fan exhausts hot air out of a PC, increasing dependability and extending component lifetime.
Product Description StarTech.com 50x10mm Replacement Ball Bearing Computer Case Fan TX3/LP4 Connector system fan kit
Product Type System fan kit
Fan Diameter 50 mm
Noise Level 25 dB
Weight 30 g
Manufacturer Warranty 1-year warranty
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 50x10mm R...
£6.97
