StarTech.com 50x50x41mm Socket 7/370 CPU Cooler Fan with Heat...
StarTech.com 50x50x41mm Socket 7/370 CPU Cooler Fan with Heatsink and TX3 and LP4
£13.89
24 in stock
Delivery:
Standard: 1-3 working days
  • Type: Case Fan
  • Stock Status: In Stock
Product codes
This startech.com socket 7/730 CPU cooling fan optimizes heat dissipation and removal by combining a large heatsink and 5cm brushless ball bearing Fan. It is designed to provide quiet cooling to socket 370(PPGA) Celerons, socket 7 Pentiums, AMD K6, K6-2 and Cyrix chips. With a high efficiency Fan blade design capable of moving 9 CFM of air, the fan draws power using a 3-lead TX3 connector that plugs directly into the motherboard, allowing the system to monitor fan speed and operating status, and includes a 4-pin LP4 adapter to maximize compatibility with existing power supplies.
Product Description StarTech.com 50x41mm Socket 7/370 CPU Cooler Fan w/ Heatsink and TX3 and LP4 processor cooler
Product Type Processor cooler
Colour Black
Compatibility Socket 370, Socket 7
Heatsink Material Aluminium
Fan Diameter 50 mm
Fan Height 12.7 mm
Fan Bearing Ball bearing
Rotation Speed 4500 rpm
Air Flow 9 cfm
Power Connector 3-pin plug, 4-pin fan connector
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 50x50x41m...
£13.89
