StarTech.com 5in Right Angle Micro USB to USB OTG Host Adapte...
StarTech.com 5in Right Angle Micro USB to USB OTG Host Adapter M/F
£6.01
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Stock Status: In Stock
Product codes
Connect your USB On-The-Go capable tablet computer or Smartphone to USB 2.0 devices (thumb drives, USB mouse or keyboard, etc.). The UUSBOTGRA Right Angle Micro USB On-The-Go Adapter Cable converts your Micro USB OTG capable Tablet or Smartphone into a USB On-The-Go host, and enables you to connect a USB peripheral device such as a flash drive, or a USB mouse or keyboard, etc. - making it perfect for hectic schedules and people on the move who need to work while traveling.
The right angle Micro USB connector allows you to position the cable and the USB device in such a way that you can still access your mobile device comfortably with reduced strain on the connection.
This OTG adapter cable is designed and constructed for maximum durability, to ensure dependable, long-lasting connections.
This adapter will only work with devices that support USB OTG. Please consult your documentation and/or your service provider to ensure that your device does support USB OTG functionality.
Product Description StarTech.com 5in Right Angle Micro USB to USB OTG Host Adapter M/F - Angled Micro USB Male to USB A Female On-The-Go Host Cable Adapter (UUSBOTGRA) - USB adapter - 12.7 cm
Type USB adapter
Technology Shielded
Features Right-angled connector
Length 12.7 cm
Connector 4 pin USB Type A - female
Connector (Second End) 5 pin Micro-USB Type B - male
Compliant Standards USB 2.0 On-The-Go
Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 5in Right...
£6.01
