StarTech.com 5in White Micro USB to USB OTG Host Adapter M/F
£6.01
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Stock Status: In Stock
Product codes
Connect your USB On-The-Go capable tablet computer or Smartphone to USB 2.0 devices (thumb drives, USB mouse or keyboard, etc.). The UUSBOTGW White Micro USB On-The-Go (OTG) Adapter Cable lets you convert the Micro USB port on your smartphone or tablet into a USB host port that you can use to connect a USB peripheral device such as a thumb drive, mouse or keyboard.
The adapter cable features one Micro USB (B-type) male connector and one full-size USB (A-type) port, and is compatible with OTG-capable devices.
To ensure dependable, long-lasting connections, the 5-inch Micro USB OTG adapter is durably constructed.
This adapter will only work with devices that support USB OTG. Please consult your documentation and/or your service provider to ensure that your device does support USB OTG functionality.
Product Description StarTech.com 5in White Micro USB to USB OTG Host Adapter M/F - Micro USB Male to USB A Female On-The-Go Host Cable Adapter - White (UUSBOTGW) - USB adapter - 12.7 cm
Type USB adapter
Technology Shielded
Length 12.7 cm
Connector 4 pin USB Type A - female
Connector (Second End) 5 pin Micro-USB Type B - male
Compliant Standards USB 2.0 On-The-Go
Colour White
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 5in White...
£6.01
