StarTech.com 5m 16.4 ft 40G QSFP+ DAC Cable
£136.38
Delivery:
Standard: 1-3 working days
Key features
  • Delivers reliable 40Gbps connections for 40GBase-T compliant networks
  • StarTech.com SFP cables are backed by a lifetime warranty
  • Uses a cost-effective cabling alternative to fiber-optic setups
  • Length: 5m
  • Colour: Black
  • Stock Status: In Stock
Product codes
Connect your MSA compliant 40GbE QSFP+ network devices with this cost-effective, passive Twinax copper cable. This 40G QSFP+ cable delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
This passive twinaxial cable is a fully hot-pluggable, direct-attach cable, supporting 40 Gigabit Ethernet applications connected through QSFP+ (Quad Small Form-Factor Pluggable) ports.
Designed for short-length, high-speed interconnects, this low-power, low-latency Twinax cable is a cost-effective alternative to fiber-optic cable assemblies, supporting short-distance applications such as point-to-point in-rack and across-rack network switch or server connections.
Product Description StarTech.com MSA Uncoded Compatible 5m 40G QSFP+ to QSFP+ Direct Attach Cable - 40 GbE QSFP+ Copper DAC 40 Gbps Low Power Passive Twinax - 40GBase direct attach cable - 5 m - black
Type 40GBase direct attach cable - SFF-8436
Technology Twinaxial
Features Passive cable
Length 5 m
Connector QSFP+ - latched
Connector (Second End) QSFP+ - latched
Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 5m 16.4 f...
£136.38
