StarTech.com 5m 16.4ft 10G SFP+ AOC Cable
£164.31
Select:
27 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 100% compatibility with Cisco SFP-10G-AOC5M guaranteed
  • StarTech.com SFP cables are backed by a lifetime warranty
  • Meets or exceeds OEM specifications and MSA (Multi-Source Agreement) industry standards
Product codes
Connect your Cisco compliant 10GbE SFP+ network devices with this cost-effective, active optical cable. This 10G SFP+ cable delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
This active optical cable (AOC) is fully hot-pluggable and supports 10 Gigabit Ethernet applications connected through SFP+ (Small Form-Factor Pluggable) ports. The AOC cable is lighter and more flexible than SFP+ direct-attach cables which makes it ideal for installation in tight spaces and over longer distances.
Designed for high-speed interconnects, this low-power, low-latency optical cable is ideal for applications such as point-to-point in-rack and across-rack network switch or server connections.
StarTech.com Cisco SFP-10G-AOC5M Comp. SFP+ AOC Fiber Cable - 5 m (16.4 ft) - 10GBase direct attach cable - 5 m - black
10GBase direct attach cable - SFF-8431/SFF-8432
Fibre optic
Active cable
Length
5 m
Connector
SFP+ - latched
Connector (Second End)
SFP+ - latched
Cisco SFP-10G-AOC5M
2 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 5m 16.4ft...
£164.31
