StarTech.com 5m 16.4ft 40G QSFP+ DAC Cable
£237.81
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • 100% compatibility with Cisco QSFP-H40G-CU5M guaranteed
  • StarTech.com SFP cables are backed by a lifetime warranty
  • Uses a cost-effective cabling alternative to fiber-optic setups
Product codes
Connect your Cisco 40GbE QSFP+ network devices with this cost-effective, passive Twinax copper cable. This 40G QSFP+ cable delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
This passive twinaxial cable is a fully hot-pluggable, direct-attach cable, supporting 40 Gigabit Ethernet applications connected through QSFP+ (Quad Small-Form Factor Pluggable) ports.
Designed for short-length, high-speed interconnects, this low-power, low-latency Twinax cable is a cost-effective alternative to fiber-optic cable assemblies, supporting short-distance applications such as point-to-point in-rack and across-rack network switch or server connections.
The QSFPH40GCU5M is a reliable replacement cable for the Cisco QSFP-H40G-CU5M.
StarTech.com Cisco QSFP-H40G-CU5M Compatible - QSFP+ Direct Attach Cable - 5 m (16.4 ft) - 40 GbE - direct attach cable - 5 m - black
Direct attach cable - SFF-8436
Twinaxial
Shielding Material
Copper
Passive cable, Hot-pluggable
Length
5 m
Connector
QSFP+
Connector (Second End)
QSFP+
2 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 5m 16.4ft...
£237.81
