StarTech.com 5m Blue Cat6 SFTP Cable
£12.08
46 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Protect your data against noise and EMI/RFI interference
  • Prevent cable damage with moulded RJ45 connectors that also offer strain relief
  • Create secured connections with snagless clips that protect the connectors during installation
Product codes
Deliver high-performance Gigabit network connections, free of noise and EMI/RFI interference. This 5-meter Cat6 cable meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections. The cable is shielded to protect your network against electromagnetic interference (EMI/RFI) and system noise, providing the perfect solution for fast and safe network connections.
Constructed with 100% copper and foil-shielded twisted-pair wiring, this cable delivers high-quality performance. It's designed to keep the data signals traveling through your network free from interference, so it's perfect in environments that are prone to large amounts of EMI.
The 50-micron gold connectors deliver optimum conductivity and eliminate signal loss due to oxidation or corrosion.
For easier cable runs, the snagless connectors protect the RJ45 clips during installation, making them less likely to snag or break. This ensures a sturdy connection by preventing the cable from becoming loose from the port.
Plus, the molded boots offer strain relief that stops the RJ45 connector termination points from bending at sharp angles, which reduces the risk of damage to the cable that could decrease network performance.
StarTech.com 5m Blue Cat6 / Cat 6 Shielded (SFTP) Patch Cable 5 m - patch cable - 5 m - blue
Patch cable - CAT 6
Shielded foiled twisted pair (SFTP)
Shielding Material
Copper
Molded, snagless
Length
5 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Blue
Fibre Connector Size
/ 50 micron
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 5m Blue C...
£12.08
