StarTech.com 5m Cisco Compatible SFP+ 10-Gigabit Ethernet (10...
StarTech.com 5m Cisco Compatible SFP+ 10-Gigabit Ethernet (10GbE) Passive Twinax Direct Attach Cable
£82.90
39 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 100% compatibility with Cisco equipment guaranteed
  • StarTech.com SFP cables are backed by a lifetime warranty
  • Length: 5m
  • Stock Status: In Stock
Product codes
Connect 10GbE SFP+ network devices with this high-quality replacement SFP-H10GB-CU5M cable. The SFPCMM5M Cisco Compatible 5m SFP+ cable is a fully hot pluggable, direct attach cable, supporting 10 Gigabit Ethernet and Fiber Channel applications connected through (Small Form Factor Pluggable) SFP+ ports.
Designed for short length, high speed interconnects, this low power, low latency Twinax cable is a cost-effective alternative to fiber optic cable assemblies and is intended for short distance applications such as point-to-point in-rack and across rack network switch/server connections.
This 10GBASE-CU SFP+ Cable is compliant with MSA (Multi-Source Agreement) standards, making it a reliable replacement SFP-H10GB-CU5M cable.
Product Description StarTech.com Cisco SFP-H10GB-CU5M Compatible SFP+ 10-Gigabit Ethernet Passive Twinax Direct Attach Cable - 5 m (16.4 ft) - 10 GbE (SFPCMM5M) - direct attach cable - 5 m
Type Direct attach cable
Technology Twinaxial
Features Latching connectors
Length 5 m
Connector SFP+
Connector (Second End) SFP+
Designed For P/N: PEX10000SFPI, PEX10GSFP4I, PEX20000SFPI
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 5m Cisco...
£82.90
