StarTech.com 5m DisplayPort 1.4 Cable
£39.09
15 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Deliver high-quality connections with a VESA certified DisplayPort cable
  • Experience crisp DisplayPort video with resolutions of up to 8K@60Hz using this 8K DisplayPort cable
  • Enjoy higher contrast ratios and vivid colors with HDR support
  • Type: DisplayPort
  • Length: 5m
  • Stock Status: In Stock
Product codes
This DisplayPort 1.4 cable lets you connect your DP laptop or desktop computer to an ultra-high definition 8K monitor, TV or projector.
The DP monitor cable provides the essential final link in your audio-video setups and is ideal for: Delivering enriched presentations; Displaying crisp digital signage walls; Creating eye-catching visuals for photography, videography, cinematography; Producing lifelike gaming.
This DP cable is VESA certified to ensure full compliance and efficient operation of the higher link rate of HBR3. It has been tested to meet all DP 1.4 specifications to ensure quality and reliability.
This 8K DisplayPort cable supports all DP 1.4 features: Resolutions up to 8K (7680x4320) @ 60Hz, backward compatible with 5K (5120x2880) @ 60Hz and 4K(4096x2160) @ 120Hz and previous generations of DP; High Bit Rate 3 (HBR3) bandwidths of 32.4Gbps; High Dynamic Range (HDR) for higher contrast ratio and vivid colors; Multi-Stream Transport (MST) for daisy-chaining multiple monitors; Display Stream Compression 1.2 (DSC); Forward Error Correction; 32 uncompressed digital audio channels; HDCP 2.2.
Each connector features latches that provide secure connections between your devices.
Product Description StarTech.com 5 m VESA Certified DisplayPort 1.4 Cable - 8K 60Hz HBR3 HDR - 16 ft Super UHD 4K 120Hz - DP to DP Slim Video Monitor Cord M/M - DisplayPort cable - 5 m
Type DisplayPort cable
Features 8K support, flexible, Ultra HD (8K) support, HBR3 support, maximum resolution 7680x4320 at 60Hz, HDR support, 32 uncompressed digital audio channels, Multi-Stream Transport
Length 5 m
Connector 20 pin DisplayPort - male - latched
Connector (Second End) 20 pin DisplayPort - male - latched
Compliant Standards DisplayPort 1.4
Colour Black
Designed For P/N: CDP2DPHD
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 5m Displa...
£39.09
