StarTech.com 5m Flat High Speed HDMI Cable with Ethernet - Ul...
StarTech.com 5m Flat High Speed HDMI Cable with Ethernet - Ultra HD 4k x 2k HDMI Cable
£16.46
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Flat HDMI® cable design fits into all those tight spots, making it a perfect solution for concealed cable runs
  • Saves money and reduces clutter by combining high bandwidth video with digital audio connections in a single cable
  • The gold-plated connectors prevent corrosion and ensure a consistent, high quality connection every time
  • Backed by StarTech.com lifetime warranty
  • Length: 5m
  • Stock Status: In Stock
Product codes
Create Ultra HD connections between your HDMI-enabled devices with minimal clutter; supports Ethernet Data Channel. The HDMM5MFL Flat High Speed HDMI Cable (5-meter) supports the advanced capabilities of the High Definition Multimedia Interface, including Ethernet data interconnectivity with compatible HDMI devices. The cable features a flat-shaft design that makes it the ideal solution for in-wall installations or installation under carpet or along baseboards.
This high quality HDMI cable fully supports 1080p+ resolutions at up to 120Hz refresh rate, with life-like color. To accommodate the demands of future high definition devices, such as increased resolutions and higher frame rates, this Ultra HD cable supports resolutions up to 4k x 2k.
Product Description StarTech.com 5m Flat High Speed HDMI Cable with Ethernet Ultra HD 4kx2k - HDMI with Ethernet cable - 5 m
Cable HDMI with Ethernet cable
Technology Shielded
American Wire Gauge (AWG) 28
Length 5 m
Colour Black
Connector HDMI - male
Connector (Second End) HDMI - male
Features 3D-Transmission
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 5m Flat H...
£16.46
