StarTech.com 5m QSFP+ Breakout Cable
Key features
  • 100% compatibility with Cisco QSFP-4SFP10G-CU5M guaranteed
  • StarTech.com SFP cables are backed by a lifetime warranty
  • Uses a cost-effective cabling alternative to fiber-optic setups
Product codes
Connect four Cisco 10GbE SFP+ network devices with this cost-effective, passive Twinax cable. This QSFP+ breakout cable connects a single QSFP+ port to four 10G SFP+ ports and delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
This passive twinaxial cable is a fully hot-pluggable, direct-attach cable, supporting 40 Gigabit Ethernet applications connected through QSFP+ (Quad Small Form Factor Pluggable) ports.
Designed for short-length, high-speed interconnects, this low-power, low-latency Twinax cable is a cost-effective alternative to fiber-optic cable assemblies. It supports short-distance applications such as point-to-point in-rack and across-rack network switch or server connections, for up to four 10G SFP+ devices.
The QSFP4SFP10C5 is a reliable replacement cable for the Cisco QSFP-4SFP10G-CU5M.
Product Description StarTech.com Cisco QSFP-4SFP10G-CU5M Compatible QSFP+ Breakout Cable - 5 m - direct attach cable - 5 m - black
Type Direct attach cable - SFF-8431/SFF-8432/SFF-8436
Technology Twinaxial
Shielding Material Copper
Features Passive cable, Hot-pluggable
Length 5 m
Connector QSFP+
Connector (Second End) 4 x SFP+
Colour Black
OEM Manufacturer Equivalent Part Number Cisco QSFP-4SFP10G-CU5M
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 5m QSFP+...
