StarTech.com 5m Yellow Cat6 Patch Cable
£6.43
Delivery:
Standard: 1-3 working days
Key features
  • RJ45 connector-clip protectors eliminate cable snags and breaks during installation
  • Yellow PVC jacket for color coding your connections
  • 5 m in length for longer connections
  • Moulded RJ45 connectors prevent cable damage and also provide strain relief
  • 50-micron gold-plated connectors for a clear signal
  • High-quality 24 AWG copper wire
  • Length: 5m
  • Colour: Yellow
  • Stock Status: In Stock
Product codes
StarTech.com N6PATC5MYL. Cable length: 5 m, Cable standard: Cat6, Connector 1: RJ-45. Weight: 180 g. Package width: 255 mm, Package depth: 330 mm, Package height: 40 mm
Product Description StarTech.com 5m CAT6 Ethernet Cable - Yellow Snagless Gigabit CAT 6 Wire - 100W PoE RJ45 UTP 650MHz Category 6 Network Patch Cord UL/TIA (N6PATC5MYL) - network cable - 5 m - yellow
Type Network cable - CAT 6
Technology Unshielded twisted pair (UTP)
Wiring Scheme T568B
Wires per Cable 8 wires
Features Snagless, stranded, PoE ready
Length 5 m
Connector RJ-45 - male
Connector (Second End) RJ-45 - male
Colour Yellow
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 5m Yellow...
£6.43
