StarTech.com 6' DP to VGA Cable with Audio
£28.70
19 in stock
Delivery:
Standard: 1-3 working days
Product codes
Connect the audio and video from your DisplayPort PC directly to a monitor. Now you can organize your workspace with less mess than ever before.
This unique 6-foot DisplayPort to VGA adapter cable features a built-in audio port, which enables you to connect a VGA monitor as well as speakers to your DisplayPort (DP) equipped desktop computer.
Remove the cable clutter from your desk. With the built-in audio port you no longer need to run a separate audio cable from your monitor or speakers directly to your desktop or laptop computer. Simply plug the audio cable from your speakers into the adapter cable for a simple and tidy solution.
In order to use the audio function of the adapter, it needs to be powered through USB. Simply connect a Micro-USB cable into the adapter from your computer, monitor or USB grommet in order to provide the necessary power.
The adapter guarantees you always have all of the connections you need. If the audio port on your computer is damaged or blocked, this adapter cable ensures you still have sound available for watching video presentations, listening to music while you work or chatting with your colleagues over Skype.
StarTech.com 6 ft / 2m DisplayPort to VGA Adapter Cable with Audio - DisplayPort adapter - 2 m
DisplayPort adapter
Length
2 m
Connectors
DisplayPort - male
Connectors (Second End)
DB-15 - male , Stereo mini jack - female , Micro-USB Type B (power only) - female
FCC, RoHS
2 years warranty
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 6' DP to...
£28.70
