StarTech.com 6" SATA Power Y Splitter Cable
£5.18
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Length: 15.2cm
  • Type: SATA
  • Stock Status: In Stock
Product codes
Add an extra SATA power outlet to your Power Supply.
The PYO2SATA SATA power splitter cable features a SATA male power connector that connects to a single computer power supply SATA connector, and breaks out into two SATA female power connectors.
The SATA power splitter/Y-cable overcomes the limit of the number of SATA drives that can be installed in the system based on available PSU power connections, and eliminates the cost of having to upgrade the power supply to accommodate an additional SATA drive.
Product Description StarTech.com 6in SATA Power Y Splitter Cable Adapter - M/F - power splitter - 15.2 cm
Type Power splitter
Length 15.2 cm
Connector 15 pin Serial ATA power - male
Connector (Second End) 2 x 15 pin Serial ATA power - female
Designed For P/N: 35BAYUSB3S4, BRACKET125PT, BRACKET125PTP, BRACKET225PT, BRACKET425F, HSB2535SATBK, S251BU31REM, S32M2NGFFPEX, SAT32MSATPEX, SATBP125VP, SATSASBP425
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 6" SATA P...
£5.18
