StarTech.com 6 ft 180° Rotating High Speed HDMI Cable -...
StarTech.com 6 ft 180° Rotating High Speed HDMI Cable - HDMI - M/M
£8.80
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Express: Delivered tomorrow
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • Two 180° HDMI Swivel/Pivot connectors
  • Supports High Speed HDMI device connections
  • Gold-plated HDMI connectors
  • Supports resolutions up to 4k x 2k
  • Type: HDMI
  • Length: 1.8m
  • Stock Status: In Stock
Product codes
Connect HDMI-capable devices even in tight spaces. The HDMIROTMM6 High Speed HDMI Swivel Cable (6 ft) features two gold plated 180° flexible HDMI connectors, which provide a direct link between HDMI-enabled devices such as Blu-Ray players, HDTVs, DVD Players, stereo receivers and more.
The swiveling/pivoting HDMI connectors offer the ability to adjust your installations in tight/narrow spaces where standard connectors will not fit (e.g. wall-mounted flat panel televisions), without having to bend the cable at sharp angles.
StarTech.com HDMI cables fully support High-Definition resolutions up to and beyond 1080p, at up to 120Hz refresh rate, with life-like color, ensuring impressive HD video performance as well as multi-channel digital audio in a single cable.
Plus, the HDMI cables can support bandwidth up to 340 MHz (10.2 Gbps) and display resolutions of up to 1440p, ready for the demands of future high definition devices, such as increased resolutions and higher frame rates.
Product Description StarTech.com 6 ft 180 Degree Rotating High Speed HDMI Cable - HDMI - M/M - HDMI cable - 1.8 m
Cable HDMI cable
Technology Double shielded
American Wire Gauge (AWG) 28
Length 1.8 m
Colour Black
Connector HDMI - male
Connector (Second End) HDMI - male
Features 180° rotating connector
Designed For P/N: HDMIEXTAA6IN
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 6 ft 180°...
£8.80
