StarTech.com 6 ft 90 Degree Down Angled Dual Link DVI-D Monit...
StarTech.com 6 ft 90 Degree Down Angled Dual Link DVI-D Monitor Cable - M/M
£11.18
12 in stock
Delivery:
Standard: 1-3 working days
  • Type: DVI
  • Length: 1.8m
  • Stock Status: In Stock
Product codes
Provides a high speed, crystal clear connection between your DVI devices, even in tight spaces. The DVIDDMMBA6 6ft Dual Link DVI-D cable features a standard DVI-D dual link connector as well as a DVI-D dual link connector that is situated on a downward angle relative to the shaft of the cable, requiring only 40mm of space at the connection point.
The perfect solution for making digital video connections in tight spaces, the design of the downward angle cable connector helps prevent damage to the cable and ensures long-lasting performance by eliminating the need to bend or strain the cable to account for a lack of space.
The 6ft DVI-D digital monitor cable supports resolutions of up to 2560x1600 and transmission rates of up to 9.9 Gbits/sec, and is fully compliant with DVI DDWG standards.
Product Description StarTech.com "6 ft 90° Down Angled Dual Link DVI-D Monitor Cable - M/M " - DVI cable - 1.8 m
Type DVI cable - dual link
Features 90° connector, molded
Length 1.8 m
Connector DVI-D - male
Connector (Second End) DVI-D - male
Compliant Standards RoHS
Colour Black
Designed For P/N: SV231DVIUAHR
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 6 ft 90 D...
£11.18
