StarTech.com 6 ft Cisco Console Rollover Cable - RJ45 Etherne...
StarTech.com 6 ft Cisco Console Rollover Cable - RJ45 Ethernet M/M
£6.48
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Length: 1.8m
  • Colour: Blue
  • Stock Status: In Stock
Product codes
Connect your computer to your Cisco router, server, or network equipment. This 6ft Cisco Console Cable/Rollover cable is a cost-effective replacement cable which enables you to connect your computer to your Cisco router, server, or network equipment. This durable Cisco Console Cable is a direct replacement cable that conforms to the Yost serial device wiring standard.
Expertly designed and constructed of only the highest quality materials, the Cisco Console Rollover cable delivers maximum dependability.
Product Description StarTech.com Cisco Console Rollover Cable - RJ45 Ethernet - network cable - 1.8 m - blue
Type Network cable
Wires per Cable 8 wires
Features Molded, flat
Length 1.8 m
Connector RJ-45 - male
Connector (Second End) RJ-45 - male
Colour Blue
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 6 ft Cisc...
£6.48
