StarTech.com 6 ft Coax High Resolution 90 degree Down Angled...
StarTech.com 6 ft Coax High Resolution 90 degree Down Angled VGA Monitor Cable - HD15 M/M
£7.88
Select:
42 in stock
Delivery:
Standard: 1-3 working days
  • Type: VGA
  • Length: 1.8m
  • Stock Status: In Stock
Product codes
This 6ft High Resolution Video VGA Cable (90 degree) is designed to provide the highest video quality possible through a VGA connection and is specifically constructed to accommodate tight installation spaces.
The high quality, shielded coax VGA cable features a 90 degree down-angled plug, which requires only 32.4mm (1.27") of space to make the video connection.
More than suitable for high-res VGA applications (1280x1024 resolution and above), the 90 degree VGA cable eliminates picture "ghosting" and fuzzy images that are common with non-coaxial cables, and provides superior EMI interference protection using ferrite cores near the connector ends.
Product Description StarTech.com "6 ft Coax High Resolution 90° Down Angled VGA Monitor Cable - HD15 M/M (MXT101MMHD6)" - VGA cable - 1.8 m
Type VGA cable
Features 90° connector, ferrite bead
Length 1.8 m
Connector HD-15 (VGA) - male
Connector (Second End) HD-15 (VGA) - male
Compliant Standards RoHS
Colour Black
Designed For P/N: CDP2VGA, CDP2VGAFC, SV221NANOU, SV231UAF, VGAPLATE
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 6 ft Coax...
£7.88
