StarTech.com 6 ft Coax High Resolution Monitor VGA Video Cabl...
StarTech.com 6 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M
£7.26
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Type: VGA
  • Length: 1.8m
  • Stock Status: In Stock
Product codes
This 6ft High Resolution VGA Monitor Cable is designed to provide the highest video quality possible through VGA. Ideally suited for high resolution VGA applications, this high quality male to male coaxial VGA cable eliminates picture "ghosting" and fuzzy images inherent to non-coaxial cables, and provides superior EMI interference protection by using ferrite cores near the connector ends.
Product Description StarTech.com 6 ft Coax High Resolution Monitor VGA Video Cable -M/M - VGA cable - 1.8 m
Type VGA cable
Technology Triple shielded twisted pair coaxial
Features Molded, ferrite bead
Length 1.8 m
Connector HD-15 (VGA) - male
Connector (Second End) HD-15 (VGA) - male
Colour Black
Designed For P/N: RKCONS2001GB, ST124UTPEAGB, ST128UTPEAGB, STUTPEALRGB, ST122UTPAEU, ST121UTPMINI, RACKCONS2001, VGA2TV2WAY2, USBVGADOCK2, USB2VGADVI, USBVGADOCKGB, ST121RGB, ST121EXTGB, ST1214TGB, ST128UTPEA, STUTPEALR, ST124UTPEA, VS410RVGAA, USBVGADOCK, ST121R, ST121EXT, ST1214T, AGPVID5500A, ST122UTPAGB
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 6 ft Coax...
£7.26
