StarTech.com 6 ft Coax High Resolution VGA Monitor Extension...
StarTech.com 6 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F
£7.20
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Ideal for high resolution monitors (1920x1200 and above)
  • Triple-coaxial + twisted-pair wire for crystal clear display
  • Impedance matched at 75 Ohms for full brightness and vibrant picture color
  • Type: SVGA
  • Length: 1.8m
  • Stock Status: In Stock
Product codes
Documents
This 6ft High Resolution VGA Extension Cable is designed to provide the highest video quality possible through VGA.
Ideally suited for high resolution VGA applications, this high quality male to female coaxial VGA extension cable helps to eliminates picture "ghosting" and fuzzy images inherent to non-coaxial cables, and provides superior EMI interference protection by using ferrite cores near the connector ends.
Product Description StarTech.com 6 ft High ResVGA Monitor extension Cable M/F - VGA extension cable - 1.8 m
Type VGA extension cable
Technology Coaxial
Features Molded
Length 1.8 m
Connector HD-15 (VGA) - male
Connector (Second End) HD-15 (VGA) - female
Designed For P/N: VGANTSCPROEU, ST124UTPEAGB, ST128UTPEAGB, HDMI2VGA, ST122UTPAEU, USB2VGAPRO, ST121UTPMINI, USBVGADOCK2, ST122VGAU, USB2VGAE2, USBVGADOCKGB, ST128WGB, ST124WGB, ST122WGB, VGA2VID, USB2VGAE, ST121RGB, ST121EXTGB, ST1214TGB, ST128UTPEA, ST124UTPEA, VS410RVGAA, USBVGADOCK, ST128W, ST124W, ST122W
Resources
The following resources are available for the StarTech.com 6 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 6 ft Coax...
£7.20
