StarTech.com 6 ft DisplayPort 1.2 Cable with Latches M/M – Di...
StarTech.com 6 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k
£13.29
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Express: Delivered on Wednesday
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • High-resolution support of up to 4K x 2K
  • Support for High Bit Rate 2 bandwidth of up to 21.6 Gbps
  • Backward compatible with DisplayPort 1.1
  • Molded latching connectors with strain relief
  • Type: Video
  • Length: 1.8m
  • Stock Status: In Stock
Product codes
Create high-resolution 4k x 2k connections with HBR2 support between your DisplayPort-equipped devices. The DISPLPORT6L 6ft DisplayPort 1.2 Cable with latches provides a secure, connection between your DisplayPort-equipped devices and is capable of providing higher performance than either HDMI or dual link DVI.
The DP cable supports high resolutions of up to 4k x 2k (3840 x 2160) @ 60Hz with a maximum HBR2 bandwidth of 21.6 Gbps. The cable also supports Multi-Stream (MST) for daisy chaining multiple monitors and provides optional audio support.
Product Description StarTech.com 6 ft Certified DisplayPort 1.2 Cable M/M with Latches DP 4k - DisplayPort cable - 1.8 m
Type DisplayPort cable
Technology Shielded
Features Latched
Length 1.8 m
Connector DisplayPort - male
Connector (Second End) DisplayPort - male
Colour Black
Designed For P/N: SV231DPUA, VS421DP, SV231DPDDUA, SV431DPUA, SV231DPU
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 6 ft Disp...
£13.29
