StarTech.com 6 ft DisplayPort to DVI Video Converter Cable - M/M
£32.05
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Plug-and-play converter makes your DisplayPort source backwards compatible with your DVI-D display
  • Easy to use, no software or drivers required
  • Single cable design offers a direct source to display solution
Product codes
Connect your DVI monitor to a DisplayPort equipped computer using a single cable. The DP2DVIMM6 DisplayPort to DVI (M-M) video converter cable lets you connect a DVI capable display to a DisplayPort video card/source using a single cable. The cable provides a connection distance of 6ft and features a male DVI connector and a male DisplayPort connector.
The DisplayPort/DVI video converter cable supports high bandwidth video transmissions, easily delivering monitor resolutions up to 1920x1200 or HDTV resolutions up to 1080p - allowing you to take full advantage of your DVI capable display, while using a cutting edge DisplayPort video source.
DP2DVIMM6 is a passive adapter cable that requires a DP++ port (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
Product Description StarTech.com 6 ft DisplayPort to DVI Video Converter Cable - 1920x1200 - DisplayPort cable - 1.8 m
Type DisplayPort cable
Length 1.8 m
Connector DisplayPort - male
Connector (Second End) DVI-D - male
Compliant Standards FCC, RoHS
Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 6 ft Disp...
£32.05
