StarTech.com 6 ft DVI-D Single Link Monitor Extension Cable -...
StarTech.com 6 ft DVI-D Single Link Monitor Extension Cable - M/F
£11.18
Select:
27 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Molded connectors with strain relief maintain a durable connection, helping to prevent damage to the connectors, for long term, error-free DVI to DVI video performance
  • Guaranteed reliability
Product codes
Extend your DVI-D (single link) connection by 6ft. The DVIDSMF6 DVI-D Single-Link Monitor Extension Cable allows you to extend the connection between your desktop workstation and DVI monitor, or your laptop and projector by up to 6-feet.
The single-link cable works with DVI digital flat panel LCD monitors and provides video data transmissions of up to 4.95 Gbps.
This durable DVI male to female cable is designed to provide a high quality digital video experience.
StarTech.com DVI-D Single Link Monitor Extension Cable - M/F - DVI extension cable - 1.8 m
DVI extension cable - single link
Length
1.8 m
Connector
DVI-D - male
Connector (Second End)
DVI-D - female
Plug and Play
P/N: ST122DVIGB, ST124DVI, ST122DVI
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 6 ft DVI-...
£11.18
