StarTech.com 6 ft HDMI to DVI-D Cable - M/M
£8.49
Select:
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Ensures compatibility between two distinct digital video interfaces
  • Eliminates the need for multiple cables and clutter
  • Guaranteed reliability
Product codes
Connect an HDMI-enabled output device to a DVI-D display, or a DVI-D output device to an HDMI-capable display. The HDMIDVIMM6 6-foot HDMI to DVI-D cable enables you to connect a DVI-D video card (or other DVI-D output device) to a display that incorporates HDMI technology; the cable supports bi-directional operation that also allows the reverse configuration, delivering digital video from an HDMI-enabled output to a DVI-D capable display.
A valuable addition to any digital signage, multimedia or home theater application, this high performance cable is designed to provide the best quality picture available through either HDMI technology or DVI digital connections.
Product Description StarTech.com 6 ft HDMI to DVI-D Cable - M/M - video cable - HDMI (M) to DVI-D (M) - 1.83 m
Cable Video cable
Length 1.83 m
Colour Black
Connector HDMI - male
Connector (Second End) DVI-D - male
Designed For P/N: SP123DP2DVI, HDMI2VGA, HDMI2HDMI, ST121HDMIT
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 6 ft HDMI...
£8.49
