StarTech.com 6 ft Mini DisplayPort 1.2 Video Extension Cable...
StarTech.com 6 ft Mini DisplayPort 1.2 Video Extension Cable M/F - Mini DisplayPort 4k
£24.02
Select:
36 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Provides a clear digital audio video signal
  • Guaranteed reliability
  • Length: 1.8m
  • Stock Status: In Stock
Product codes
Create a high-resolution 4k x 2k extension with HBR2 support between your Mini DisplayPort -equipped devices. This Mini DisplayPort 1.2 cable lets you extend the connection distance between your Mini DP devices by up to 6 feet.
The cable delivers the ideal solution for better placement of peripheral devices and can be used to connect your Microsoft Surface Pro 4, Surface Book, MacBook, MacBook Pro, MacBook Air, and other mDP enabled devices to Apple's LED Cinema Display or other Mini DisplayPort monitor.
Simply connect your tablet or laptop to the extension cable using a standard MDISPLPORT6" text="Mini DisplayPort Cable and connect the extension cable to your Mini DP monitor.
The cable supports high resolutions of up to 4k x 2k (3840 x 2160) @ 60Hz with a maximum HBR2 bandwidth of 21.6 Gbps. The cable also supports Multi-Stream (MST) for daisy chaining multiple monitors and provides optional audio support.
Please note: Newer laptop and desktop computers (e.g. Apple) come equipped with Thunderbolt ports only. The Mini DisplayPort Cables can be connected to the Thunderbolt ports, enabling you to connect your Mini DP compatible displays.
Product Description StarTech.com 6 ft Mini DisplayPort 1.2 Video Extension Cable M/F - Mini DisplayPort 4k with HBR2 support - Mini DP Extension Cable 6 feet (MDPEXT6) - DisplayPort extension cable - 1.8 m
Type DisplayPort extension cable
Technology Double shielded
Features Latched, molded
Length 1.8 m
Connector Mini DisplayPort - female
Connector (Second End) Mini DisplayPort - male
Compliant Standards RoHS
Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 6 ft Mini...
£24.02
