StarTech.com 6 ft Mini DisplayPort to DVI Cable - M/M
£27.63
20 in stock
Delivery:
Standard: 1-3 working days
Key features
  • All-in-one cable design for ease of use and optimal cable management
  • Supports resolutions up to 1920x1200 (PC), and 1080p (HDTV) for an optimal viewing experience
  • No software or driver installation allows for an easy and hassle-free connection to your DVI display
  • Type: DVI
  • Length: 1.8m
  • Stock Status: In Stock
Product codes
Connect your DVI monitor to a Mini DisplayPort-equipped computer using a single cable.
The MDP2DVIMM6 6-foot Mini DisplayPort to DVI Cable is a cost-effective Mini DisplayPort to DVI link that lets you connect a DVI monitor to a PC or Mac with a Mini DisplayPort output - saving the expense of upgrading the monitor for compatibility. This all-in-one, easy to use Mini DisplayPort/DVI cable requires no additional converters or adapters, and no driver or software installation.
Compatible with Intel Thunderbolt, when connected directly to a supporting DisplayPort over Thunderbolt I/O port.
MDP2DVIMM6 is a passive adapter that requires a DP++ port (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
Product Description StarTech.com 6 ft Mini DisplayPort to DVI Cable - M/M - DisplayPort cable - 1.8 m
Type DisplayPort cable
Length 1.8 m
Connector Mini DisplayPort - male
Connector (Second End) DVI-D - male
Compliant Standards FCC, RoHS
Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 6 ft Mini...
£27.63
