StarTech.com 6 ft Mini DisplayPort to VGA Cable - M/M
£38.94
Delivery:
Standard: 1-3 working days
Key features
  • All-in-one cable design for ease of use and optimal cable management
  • Resolution support of up to 1920x1200 and HDTV resolutions up to 1080p for optimal viewing experience
  • No software or additional driver installation allows for an easy and hassle-free connection to your VGA display
  • Type: DisplayPort
  • Length: 1.83m
  • Stock Status: In Stock
Product codes
Connect your VGA monitor to a mini DisplayPort-equipped computer using a single cable. The MDP2VGAMM6 6-foot mini DisplayPort to VGA cable is a cost-effective mini DisplayPort to VGA link that lets you connect a VGA monitor to a PC or Mac with a mini DisplayPort output - saving the expense of upgrading the monitor for compatibility.
Compatible with Intel Thunderbolt, when connected directly to a supporting DisplayPort over Thunderbolt I/O port. This all-in-one, easy to use Mini DisplayPort/VGA cable requires no additional converters or adapters, and no driver or software installation.
Product Description StarTech.com 6 ft. (1.8 m) Mini Displayport to VGA Cable - 1920x1200 / 1080p - Thunderbolt Compatible - VGA Monitor Cable (MDP2VGAMM6) - video converter - black
Device Type Video converter
Max Resolution 1920 x 1200
Interfaces 1 x DisplayPort output - Mini DisplayPort , 1 x VGA input - 15 pin HD D-Sub (HD-15)
Enclosure Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 6 ft Mini...
£38.94
