StarTech.com 6 ft Professional RS422/485 USB Serial Cable Ada...
£48.58
13 in stock
Delivery:
Standard: 1-3 working days
Product codes
Add an RS422/485 serial port to your system through USB; features COM port retention.
The ICUSB422 6 ft Professional RS422/485 USB Serial Cable Adapter with COM Port Retention lets you connect RS422 or RS485 serial devices to your USB-enabled computer. The adapter features a 9-pin (DB9) male serial connector as well as dipswitch controls for easy port configuration, and requires minimal software. The RS422/RS485 USB Adapter is fully powered via the host USB connection and provides power to the attached serial device without requiring an external power adapter. COM Port Retention saves the assigned port settings, allowing you to disconnect and re-connect the adapter with little to no configuration required on the host computer.
Product Description StarTech.com 6 ft 1 Port RS422 RS485 USB Serial Cable Adapter - serial adapter
Device Type Serial adapter
Form Factor External
Interface (Bus) Type USB
Ports RS-422/485
Data Link Protocol RS-485, RS-442
Data Transfer Rate 921.6 Kbps
System Requirements Linux, Microsoft Windows 2000, Apple MacOS 9.x, Apple MacOS X 10.x, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows CE 4.2 or later, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 6 ft Prof...
£48.58
