StarTech.com 6 ft USB 2.0 Extension Cable A to A - M/F
£4.22
33 in stock
Delivery:
Standard: 1-3 working days
Product codes
This high quality 6ft USB A-A extension cable features one USB A male connector and one USB A female connector, extending the connection between USB 2.0 devices by up to 6 feet - an ideal solution for better placement of peripheral devices, or adding flexibility to existing USB ports. The USB extension cable is fully rated for use with USB 1.1 and USB 2.0 devices.
StarTech.com 6 ft USB 2.0 Extension Cable A to A - M/F - USB extension cable - 1.8 m
USB extension cable
Molded
Length
1.8 m
Connector
4 pin USB Type A - male
Connector (Second End)
4 pin USB Type A - female
P/N: RKCONS2001GB, RACKCONS2001, DP2DVID, USB2IR2, 35FCREAD20, 35FCREAD20BK, CB100LANUSB2, USB555WG, 35FCREAD, 35FCREADBK, FCREADMINI, 35FCREADREM
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 6 ft USB...
£4.22
