StarTech.com 6 ft USB to DB25 Parallel Printer Adapter Cable...
StarTech.com 6 ft USB to DB25 Parallel Printer Adapter Cable - M/F
£8.98
Select:
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • USB interface allows you to quickly add another parallel port to your Windows 98/ME/2000/XP/Vista/7 computer
  • Plug and play USB design eliminates the need for manual or automatic parallel switch boxes
  • Compact size and low weight make it an ideal accessory for portable computers
  • Length: 1.86m
  • Stock Status: In Stock
Product codes
Add a DB25 parallel port to your desktop or laptop PC through USB. The ICUSB1284D25 6 ft USB to DB25 parallel printer adapter cable turns an available USB port on a host PC into a DB25 female parallel port - allowing you to connect a DB25 printer to the computer as if the necessary parallel port was built-on.
A cost-effective and reliable solution, the USB to DB25 adapter saves the expense of replacing a parallel printer for the sake of USB capability.
Product Description StarTech.com 6 ft / 2m USB to DB25 Parallel Printer Adapter Cable - 2 Meter USB to IEEE-1284 Printer Cable - USB A to DB25 M/F (ICUSB1284D25) - parallel adapter
Device Type Parallel adapter
Form Factor External
Interface (Bus) Type USB 2.0
Ports IEEE 1284
Length 1.86 m
Data Link Protocol Parallel
Data Transfer Rate 1.5 Mbps
Processor Prolific PL-2305
System Requirements Microsoft Windows 98 Second Edition, Microsoft Windows 2000, Apple MacOS X 10.4 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits)
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 6 ft USB...
£8.98
