StarTech.com 6 Port Industrial Gigabit Ethernet Switch, 4 PoE...
StarTech.com 6 Port Industrial Gigabit Ethernet Switch, 4 PoE+ Ports and Voltage Regulation
£266.88
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Product codes
Connect Gigabit Ethernet data and power to 4 PoE-enabled devices, with 2 additional GbE ports - DIN/Wall Mountable. The IES61002POE 6-Port Industrial PoE+ switch lets you connect Gigabit Ethernet data and power to four PoE-enabled devices, with two additional GbE ports.
Fully compliant with IEEE 802.3at / 802.3af, the industrial Ethernet switch offers up to 30 Watts output per port, through the four PoE+ / PSE ports, while all six shielded RJ45 ports support auto-negotiation of speed and duplex for 10/100/1000Mbps Ethernet networks.
Providing seamless power failover in the event of power dips or failures, the switch features redundant 20-57V DC (nominal 24/48V DC) terminal block power inputs. The switch also features an internal DC-DC converter, which provides the PoE injector with high voltage output from a low voltage input (<24V DC). When used with multiple power sources, the switch supports alarm relay contacts, which can be wired to your existing alarm circuit to give you instant notice when a power disruption occurs.
To ensure dependable performance in harsh environments, this power over Ethernet switch features an extended operating temperature range (-40°C to 75°C), a rugged IP-30 rated case design and includes both DIN-Rail and wall-mount brackets for flexible installation options.
StarTech.com 6 Port Unmanaged Industrial Gigabit Ethernet Switch with 4 PoE+ Ports - DIN Rail / Wall-Mountable - switch - 6 ports - unmanaged
Switch - 6 ports - unmanaged
Subtype
Gigabit Ethernet
Ports
4 x 10/100/1000 (PoE+) + 2 x 10/100/1000
Power Over Ethernet (PoE)
PoE+
Auto-uplink (auto MDI/MDI-X), store and forward, full duplex mode
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at
DC 24/48 V
6.3 cm x 10.6 cm x 13.5 cm
840 g
2 years warranty
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 6 Port In...
£266.88
