StarTech.com 60 ft Coax High Resolution Monitor VGA Cable - H...
StarTech.com 60 ft Coax High Resolution Monitor VGA Cable - HD15 M/M
£36.92
Delivery:
Standard: 1-3 working days
  • Length: 18.3m
  • Stock Status: In Stock
Product codes
Connect your VGA monitor with the highest quality connection available. This 60-foot High Resolution VGA Monitor Cable is designed to provide the highest video quality possible through VGA. Ideally suited for high resolution VGA applications, this high quality male-to-male coaxial VGA cable eliminates the picture "ghosting" and fuzzy images that are inherent to non-coaxial cables, while providing superior EMI interference protection by using ferrite cores near the connector ends.
Product Description StarTech.com 60 ft Coax High Resolution Monitor VGA Cable - HD15 M/M - VGA cable - 18.3 m
Type VGA cable
Technology Triple shielded twisted pair coaxial
Features Ferrite bead
Length 18.3 m
Connector HD-15 (VGA) - male
Connector (Second End) HD-15 (VGA) - male
Compliant Standards NEC-CMG
Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 60 ft Coa...
£36.92
