This open SFP PoE fiber media converter offers an easy, inexpensive way to extend the reach of your data and power devices at remote locations using your network over fiber, using the SFP of your choice. It combines the data connectivity of a media converter with the flexible power supply capabilities of a PoE injector. The converter provides a powerful networking solution for campuses, warehouses, factories or any applications that require POE and connectivity over long distances.
Product Description | StarTech.com PoE+ Industrial Fiber to Ethernet Media Converter 60W, SFP to RJ45, Singlemode/Multimode Fiber to Copper Gigabit Ethernet, Compact, IP-30/ -40 to +75C, PoE+ Media Converter - Fiber Media Converter (IMC1GSFP60W) - fibre media converter - 10Mb LAN, 100Mb LAN, GigE | Device Type | Fibre media converter - RJ-45 / SFP (mini-GBIC) | Form Factor | DIN rail mountable | Cabling Type | 1000Base-SX, 1000Base-T | Data Transfer Rate | 1 Gbps | Data Link Protocol | 10Mb LAN, 100Mb LAN, GigE | Max Transfer Distance | 10 km | Power Over Ethernet (PoE) | PoE+ | Dimensions (WxDxH) | 8.15 cm x 10.4 cm x 3.2 cm | Weight | 153 g | Manufacturer Warranty | 2-year warranty |
General | |
Device Type | Fibre media converter |
Colour | Black |
Networking | |
Connectivity Technology | Wired |
Status Indicators | Port status, active, PoE, link |
Features | Flow control, auto-uplink (auto MDI/MDI-X), full duplex mode, 512KB packet buffer, 2KV Surge protection, 16 KB Jumbo Frame |
Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.3x |
Expansion / Connectivity | |
Interfaces | 1 x Ethernet 1000Base-T - RJ-45 female - 60 W , 1 x Ethernet 1000Base-SX - SFP female |
Miscellaneous | |
Included Accessories | Power terminal block |
Mounting Kit | Included |
MTBF | 561556 hours |
Compliant Standards | IEC 61000-4-2, IEC 61000-4-4, IEC 61000-4-5, FCC, RoHS, EN 60950-1, WEEE, MSA, IP30, EN 60068-2-27, EN 60068-2-32, EN 60068-2-6, IEEE 802.3af, IEEE 802.3at |
Power | |
Power Device | External power adapter |
Dimensions & Weight | |
Width | 8.15 cm |
Depth | 10.4 cm |
Height | 3.2 cm |
Weight | 153 g |
Dimensions & Weight (Shipping) | |
Shipping Width | 21.1 cm |
Shipping Depth | 16.2 cm |
Shipping Height | 6.4 cm |
Shipping Weight | 400 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | -40 °C |
Max Operating Temperature | 75 °C |
Humidity Range Operating | 5 - 95% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
