StarTech.com 60x10mm Replacement Ball Bearing Computer Case F...
StarTech.com 60x10mm Replacement Ball Bearing Computer Case Fan with TX3 Connector
£6.25
More than 50 in stock
Delivery:
Standard: 1-3 working days
Product codes
Overheating hardware can be a problem in most server rooms. With StarTech.com's new LP4 Replacement Ball Bearing Fan, you can avoid problems to workstations.
StarTech.com 60x10mm Replacement Ball Bearing Computer Case Fan w/ TX3 Connector - system fan kit
System fan kit
Fan Diameter
60 mm
Noise Level
28 dB
Dual ball bearing
1 cm x 6 cm x 6 cm
38 g
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 60x10mm R...
£6.25
