Overheating hardware can be a problem in most server rooms. With StarTech.com's new LP4 Replacement Ball Bearing Fan, you can avoid problems to workstations.
Product Description | StarTech.com 60x10mm Replacement Ball Bearing Computer Case Fan w/ TX3 Connector system fan kit | Product Type | System fan kit | Fan Diameter | 60 mm | Noise Level | 28 dB | Features | Dual ball bearing | Dimensions (WxDxH) | 1 cm x 6 cm x 6 cm | Weight | 38 g | Manufacturer Warranty | 2-year warranty |
General | |
Width | 1 cm |
Depth | 6 cm |
Height | 6 cm |
Weight | 38 g |
Shipping Dimensions (WxDxH) / Weight | 48 g |
Security Cable Lock | |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | -10 °C |
Max Operating Temperature | 80 °C |
