StarTech.com 60x20mm Replacement Ball Bearing Computer Case F...
StarTech.com 60x20mm Replacement Ball Bearing Computer Case Fan with TX3 Connector
£10.54
More than 50 in stock
Delivery:
Standard: 1-3 working days
Product codes
StarTech is a high technology company that designs, manufactures and distributes a complete line of computer cables, parts, peripheral sharing and networking products, and productivity enhancing accessories.
With StarTech.com's new Replacement Ball Bearing Fan, you can avoid overheating problems caused by fan failure.
Product Description StarTech.com 60x20mm Replacement Ball Bearing Computer Case Fan w/ TX3 Connector system fan kit
Product Type System fan kit
Fan Diameter 60 mm
Fan Height 20 mm
Rotation Speed 4500 rpm
Air Flow 22.1 cfm
Noise Level 28 dB
Power Connector 3-pin plug
Features Dual ball bearing
Dimensions (WxDxH) 6 cm x 6 cm x 2 cm
Weight 38 g
Designed For P/N: RMC4450
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 60x20mm R...
£10.54
