StarTech.com 60x25mm High Air Flow Dual Ball Bearing Computer...
StarTech.com 60x25mm High Air Flow Dual Ball Bearing Computer Case Fan with TX3
£7.86
Delivery:
Standard: 1-3 working days
  • Type: Case Fan
  • Stock Status: In Stock
Product codes
This 6cm x 2.5cm (5000 RPM) Computer Case Fan helps prevent computer systems from overheating, thereby increasing efficiency and stability.
The fan features a TX3 connection and a built-in tachometer that sends RPM signals to your motherboard - a high-performance solution that can help avoid overheating and system failure.
Product Description StarTech.com 60x25mm High Air Flow Dual Ball Bearing Computer Case Fan w/ TX3 system fan kit
Product Type System fan kit
Fan Diameter 60 mm
Dimensions (WxDxH) 6 cm x 6 cm x 2.5 cm
Weight 25 g
Features Fan speed monitoring
Manufacturer Warranty 1-year warranty
Designed For P/N: RMC4450
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 60x25mm H...
£7.86
