StarTech.com 60x65mm Socket A CPU Cooler Fan with Heatsink fo...
StarTech.com 60x65mm Socket A CPU Cooler Fan with Heatsink for AMD Duron or Athlon
£9.91
Delivery:
Standard: 1-3 working days
  • Type: Heatsink
  • Stock Status: In Stock
Product codes
This entry-level heatsink is specifically designed for AMD Athlon and Duron processors. This heatsink with fan provides enough cooling power for most Athlon and Duron CPUs without costing a fortune. It is suitable for Duron CPUs up to 1300 MHz, Thunderbird Athlon CPUs up to 1333 MHz and Athlon XP CPUs up to 2000+ MHz.
Product Description StarTech.com 60x65mm Socket A CPU Cooler Fan with Heatsink for AMD Duron or Athlon processor cooler
Product Type Processor cooler
Compatibility Socket A
Fan Diameter 60 mm
Fan Height 20 mm
Rotation Speed 4000 rpm
Air Flow 23.2 cfm
Noise Level 31 dBA
Power Connector 3-pin plug
Features Ball bearing
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 60x65mm S...
£9.91
