StarTech.com 65x60x45mm Socket 7/370 CPU Cooler Fan with Heat...
StarTech.com 65x60x45mm Socket 7/370 CPU Cooler Fan with Heatsink & TX3 connector
£7.53
37 in stock
Delivery:
Standard: 1-3 working days
  • Type: Heatsink
  • Stock Status: In Stock
Product codes
The StarTech.com Socket 7/370 CPU Cooler with its 2cm fan cooling fan is a combination heatsink and fan designed to cool high-performance CPUs. It sports an extra-large heatsink with enough cooling capacity for Pentium III and Celeron CPUs up to 1.4 GHz. A quiet running 6x2 cm brushless ball bearing DC motor coupled with a high-efficiency blade design is capable of moving 21.46 CFM (cubic feet per minute) of air. Power is supplied to the fan using a 3-lead TX3 connector that plugs into the motherboard and allows the system to monitor fan speed and operating status. For LP4 connection, add optional accessory CPUFANADAPT.
Product Description StarTech.com 65x60x45mm Socket 7/370 CPU Cooler Fan w/ Heatsink & TX3 connector processor cooler
Product Type Processor cooler
Compatibility Socket 370, Socket 7
Fan Diameter 60 mm
Fan Height 20 mm
Rotation Speed 4000 rpm
Air Flow 20.2 cfm
Noise Level 31 dBA
Power Connector 3-pin plug
Features Ball bearing
Manufacturer Warranty 1-year warranty
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 65x60x45m...
£7.53
