StarTech.com 6ft HDMI to VGA adapter cable
£32.07
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Reduce clutter in your classroom or workstation with a precise 6 foot cable connecting your HDMI computer to your VGA display
  • Hassle-free installation with cable-style adapter enabling you to connect your HDMI source directly to a VGA display with no additional video cable required
  • Save upgrade costs by connecting your HDMI computer to an existing VGA monitor, projector or television
  • Stock Status: In Stock
Product codes
Eliminate adapters, by connecting your HDMI source directly to a VGA monitor/projector using this 6ft adapter cable. The HD2VGAMM6 6ft HDMI to VGA converter cable lets you connect your HDMI equipped Chromebook, laptop or desktop to a VGA monitor or projector, with no additional adapters or cables required.
The converter cable saves you the hassle of combining an HDMI to VGA adapter with a bulky VGA cable by providing an end-to-end solution for connecting your digital HDMI computer to your VGA monitor or projector.
Unlike most HDMI to VGA adapters which require a power outlet to convert the video signal, the HD2VGAMM6 doesn't need external power in most installations. To work with Mac computers where extra power is needed, the HD2VGAMM6 features an optional integrated USB power source (USB cable not included), which makes connecting a display to your desktop or workstation that much easier, if additional power is required.
In the past, converting digital HDMI to analog VGA was a difficult and expensive task. Now, you can avoid upgrade costs by connecting your HDMI video source to your existing VGA monitor or projector using the HD2VGAMM6. Plus, because the adapter cable supports video resolutions up to 1920x1200 or 1080p, you can rest assured you can use your existing VGA display while maintaining high-definition video quality.
The HD2VGAMM6 converter cable delivers a precise 6ft connection that eliminates the clutter of excess cable length and ensures a tidy, professional installation. For longer shorter installations, StarTech.com offers a 3 ft HDMI to VGA cable (HD2VGAMM3), and longer installations StarTech.com offers a 10 ft HDMI to VGA cable (HD2VGAMM10), enabling you to choose the right cable length for your installation needs.
Digitally encrypted content from the HDMI video source will not be displayed.
Product Description StarTech.com HDMI to VGA Cable – 6ft 2m - 1080p – Active Conversion – HDMI to VGA Adapter Cable for Your VGA Monitor / Display (HD2VGAMM6) - video converter - black
Device Type Video converter
Max Resolution 1920 x 1200
Interfaces 1 x HDMI input - 19 pin HDMI Type A , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x USB (power only) - 5 pin Micro-USB Type B (power only)
Enclosure Colour Black
Designed For P/N: MST30C2DPPD
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 6ft HDMI...
£32.07
